Activity › Forums › Apple Final Cut Pro Legacy › fields being labeled wrong on import
Jeremy Garchow replied 17 years, 2 months ago 9 Members · 26 Replies
Josh Weiss
June 21, 2007 at 8:59 pmGary,
I realize that this is an option, but I have had problems in the past with text overlays and still frames in FCP 5 when I have the sequence set to anything but none.
Also, because we are rendering None (progressive) from After effects, won’t that still be looked at incorrectly by fcp. Even though it seeing the render as lower, its really progressive.
Any advice…
Martin Baker
June 21, 2007 at 9:51 pmYes, you can very easily change parameters of multiple clips in the Browser. Tip – drag the Field Dominance column all the way to the left so it’s easy to access, then select the AE files and right-click in the Field Dominance column to set all the clips to “None”. You should be doing this before editing them into a sequence.
Martin
Digital Heaven, London UK
Unique plug-ins and tools for Apple Pro Apps
Avid2FCP
For Avid editors learning FCP -
Toma Ever
July 19, 2009 at 2:22 pmi use the same “progressive workflow” for sd, and i unfortunately have the same problem in fcp.
i just wanted to correct gary, PAL is lower field first, NTSC upper… -
Tom Wolsky
July 19, 2009 at 2:29 pmThat’s wrong. It’s the other way around for uncompressed standard definition. PAL upper, NTSC lower. For DV both NTSC and PAL are lower.
All the best,
Tom
Class on Demand DVDs “Complete Training for FCP6,” “Basic Training for FCS2” and “Final Cut Express Made Easy”
Author: “Final Cut Pro 5 Editing Essentials” and “Final Cut Express 4 Editing Workshop” -
Rafael Amador
July 19, 2009 at 4:28 pmThat FC can not recognize the proper field order on importing is nothing new.
Solution: Have a look to the Browser whenever you import anything.
As per the field order:
– DV (DV25/50) is always Lower in PAL and NTSC.
– 8/10b Uncompress and Prores is Lower for NTSC and Upper for PAL.
Those are acquisition codecs. Intermediate codecs (like Animation) are up to the need of the user.
Yesterday was posted here a very interesting link:
https://forums.creativecow.net/readpost/8/1044461
Rafael
PS: Thanks God all the HD interlaced formats are Upper. -
Jeremy Garchow
July 20, 2009 at 3:47 pm[toma euvrie] “i use the same “progressive workflow” for sd, and i unfortunately have the same problem in fcp. “
What codec are you using?
