Activity › Forums › Adobe After Effects › fieldorder again
  • fieldorder again
    Posted by Christofer Wetterholm on November 12, 2009 at 1:24 pm
    Hello again!
    I´ve been trying to get to the bottom with my interlaced file problem with alot of help from you guys thanks!!!
    I sent the file to a friend so he could take a look at it and see if the fieldorder was correct or not and he said that it seemed like the file was converted from 24P or NTCS 29.97 to 25 fps pal with interlacing and therefore some frames where interlaced and some progressive…..
    Is this a problem when i am going to ad grafics and text and then render out a movie for broadcast?
    Should i try to get some other material? or can i use the one i got….
    I am a little confused now…
    /Christofer
    Christofer Wetterholm replied 16 years, 10 months ago 1 Member · 0 Replies
  • 0 Replies
