Activity › Forums › Apple Final Cut Pro Legacy › field shift on mix
  • field shift on mix
    Posted by Jonathan Griffiths on September 2, 2010 at 7:57 pm
    HI I have some PAL-DV sequences from a client, most of the footage is PAL-DV and the other footage I have added a field shift filter to. My problem is that at the start a mix the picture shifts up one line then back down at the end, also when using push effect i am have some field issues as well. the sequence are set to PAL-DV am I missing something else. I am a new convert from Avid so it could be something very silly to you. Thanks for your help Jonathan
    Jonathan Griffiths replied 16 years ago 2 Members · 2 Replies
  • John Fishback
    September 2, 2010 at 9:30 pm
    Is this happening during a transition? If so, it might be a render issue. Select/highlight the transition(s) and render by going to Sequence Menu > Render Only > Full. Even when there is no render line over the transition this is sometimes necessary. I’ve never found out why. It’s just one of those little “things.”
    John
    MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.8 QT7.6.4 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24″ TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
    FCS 3 (FCP 7.0.2, Motion 4.0.2, Comp 3.5.2, DVDSP 4.2.2, Color 1.5.2)
  • Jonathan Griffiths
    September 5, 2010 at 3:05 pm
    Hit the nail on the head interestingly shots either side developed feild issues sorted by field shifting bit strange but who cares if it works thats ok with me
