Activity Forums Adobe After Effects Field Rendering Problem
  • Field Rendering Problem
    Posted by James Fletcher on December 16, 2005 at 12:06 pm
    I have a project composed of a lot of interlaced video clips that fly back into 3D space with a 3D camera move on them, and whenever I try to render out my movie using the field rendering option, I end up with horrible looking thick black horizontal lines on each of my video clips within the frame. I have tried both lower field first and upper field first, both uncompressed and animation compressor Quicktimes, but the results are the same.
    I am using AE 6.0 PE.
    If anyone has any solutions for me, I’d appreciate it.
    James
    James Fletcher replied 20 years, 9 months ago 3 Members · 4 Replies
  • Steve Roberts
    December 16, 2005 at 5:10 pm
    Did you separate fields when you imported the footage? It sound like you should have, if you didn’t. Check the AE help on “interpretation”.
  • James Fletcher
    December 16, 2005 at 9:36 pm
    Yesterday, as a test, I used the interpret fields function to separate the fields. I changed my sequence frame rate to 59.94, and then when making my movie I set the frame rate back to 29.97. Unfortunately, my video clips still ended up looking like they were shot through a venitian blind.
  • Andrei
    December 16, 2005 at 10:51 pm
    in the 3d aplication, what is the field order?
  • James Fletcher
    December 16, 2005 at 11:11 pm
    Sorry if I haven’t been clear. I haven’t used a separate 3d application, I’ve just been using the 3D functions in AE 6.0.
    All of my source footage comes from uncompressed Quicktimes exported out of an Avid Meridian from an original Digibeta NTSC source (tapes digitized at 1 to 1 maximum resolution). When I experimented with interpreting my footage in AE, I used the lower field first setting.
