Activity Forums Apple Motion Field rendering in Motion 1.0
  • Field rendering in Motion 1.0
    Posted by Brian Charles on April 25, 2005 at 9:29 pm
    Is it just me or is field rendering screwed up in Motion? Footage is fine in FCP but motion shows terrible artifacts from incorrect field dominance regardless of the settig.
    Brian Charles replied 21 years, 4 months ago 2 Members · 2 Replies
  • Mark Spencer
    April 26, 2005 at 3:04 am
    Make sure your project settings (command-J) match your video material – it’s easy to accidentally put DV material in an SD timeline. Also, to double-check, view on an NTSC monitor – it can be normal to see interlacing on the computer that won’t show on the monitor (FCP only shows one field in the Canvas by default).
    Mark Spencer
    Freelance Editor/Producer
    Apple-certified instructor, Final Cut Pro and Motion
    Author, Motion Visual Quickstart Guide from Peachpit Press (coming soon)
    https://www.applemotion.net
  • Brian Charles
    April 27, 2005 at 3:21 am
    Thank you. This was the problem. Preview on my external NTSC monitor is now fine.
