Activity Forums Boris FX Particle Illusion Field rendering — help
  • Field rendering — help
    Posted by Alan Lorence on February 21, 2006 at 3:49 pm
    Does anybody use particleIllusion (Windows) with field rendering?
    Do you ever load AVIs that use fields, then add the particles, render with fields, leaving the background AVI in the pIllusion output?
    A user is having trouble with the background AVI “flickering” after rendering from pIllusion — this indicates a problem with the fields. He has done this sucessfully in the past (with no flickering) using only pIllusion, but has forgotten the settings he used to get it working.
    Anybody? (I understand this is fairly urgent)
    Alan.
    wondertouch
    Jose Burgos replied 20 years, 7 months ago 5 Members · 4 Replies
  • Bas Wolters
    February 22, 2006 at 10:54 am
    Try switching the field priority, i.e. lower or upper field first. I believe PAL and NTSC are opposite field priorities.
  • Greg Paterson
    February 22, 2006 at 11:48 am
    Yep …..I would say also WRONG field order.
    Lower Field first for PAL.
    Works for me in PAL-land (AUS) …never a problem …. if you set everthing correct in the firstplace.
    But be aware ….. some apps have the fields wrong.!
    So one needs to experiment… ie test the app with different field order if flicker is detected.
    Greg
    http://www.teliocide.com
    http://www.3D_Icthyomania.com
    http://www.croc_swamp_fishing.com
    http://www.tropical_carp.com
  • Jeff Bellune
    February 22, 2006 at 4:07 pm
    NTSC is also lower-field first for DV and DVD.
    -Jeff
  • Jose Burgos
    February 26, 2006 at 4:23 am
    This is what I use:
    480 lines even first.
    486 lines odd first.
    Take care,
    Jose Burgos
