Activity Forums Adobe After Effects Field render looks too corporate, frames too jittery – is there a third way?
  • Field render looks too corporate, frames too jittery – is there a third way?
    Posted by Ste Kerouac on January 12, 2007 at 11:45 pm
    I’m doing a very simple animation of some rotoscoped silhouettes and Illustrator vector graphics. They pan across the screen at a constant speed. Very simple so far. I’ve rendered out 4 test files – with motion blur on and off and with field render on and off. The field rendered footage looks ‘too’ smooth on the monitor – like a corporate video type of quality. The frame rendered stuff all jitters mostly around the vertical edges.
    Is there some third way? I know later I’m going to apply grain, vary the lighting a little etc etc to give it a more filmic, cel-animated look, but the motion itself is the issue. Anybody know of any tricks…?
    Maybe a Posterize time set to 24fps or a different shutter angle in the motion blur or something? I want it clean but old, filmic animation looking…
    Jimmy Brunger replied 19 years, 8 months ago 2 Members · 1 Reply
  • Jimmy Brunger
    January 13, 2007 at 2:58 pm
    Maybe try a tiny bit of gaussian blur on the edges? I did a very similar siloutte roto job the other week and some of the edges looked jittery and jagged – 0.1-0.2 pix gaussian pretty much sorted it. If your look is old filmic, it should be a tad blurred anyway, so maybe add more rather than less. Also, motion blur can make a bit of a mess on some roto shapes – wrongly interpreting it if the shapes is moving fast (probs not an issue for your proj) The only way I could fix it was to break the character (man jumping in the air in this case) into as many separate shapes as possible – breaking the arms at the elbow helped.
    Good luck.
    *Production Studio Premium / *Combustion 3
    Win XP Pro SP2 / Intel P4 3GHz / 2GB RAM / GeForce FX5200 / DeckLink Pro / Sony BVM-20G1E / DVS SDI Clipstation / 110GB boot/80GB media/600GB RAID-0
