Activity Forums DaVinci Resolve field problems in resolve 8.1
  • field problems in resolve 8.1
    Posted by Diana Cuyàs on January 24, 2012 at 10:41 am
    Hi!
    I’ve scanned 35mm material at 1k resolution, in order to make a colour correction and play it out to betadigi PAL
    i’ve made a project with pal settings on video output monitoring, while we are play on or just stopped everything is fine, but when we just touch anything of colour the image in the monitor turns in to one single field and you can’t see it properly ( you can see the edges broken) I know there’s an option about “single fild when stopped”, i have this setting turned off…
    I don’t know if I made myself clear…
    at the moment we’ve decided ( just to start working) to turn the output video monitoring at HD720p, but anyone else has had this problem?
    thanks
    Diana
    Rohit Gupta replied 14 years, 8 months ago 3 Members · 3 Replies
  • Charlie Edison
    January 26, 2012 at 8:51 am
    what did you use to scan the film, film scanners should be progressive ?!
  • Diana Cuyàs
    January 26, 2012 at 9:31 am
    yes, I know, the scan is progressive, I think is something about the displaying with the monitor, but is strange, because only happens when you touch the table ( impresario)
    I can play out correctly, but it’s dificult to work like that with the client….
  • Rohit Gupta
    January 26, 2012 at 9:38 am
    There’s a setting in the Decklink Control Panel to “Remove jitter when paused”. Try switching it off.
