Activity Forums Adobe After Effects Field problem DV PAL
  • Field problem DV PAL
    Posted by Ronald on May 13, 2007 at 7:43 pm
    I’m using PAL DV
    When i export from AE using animation codec or uncompressed my movies stutter in Final Cut. (Final Cut says it’s upper field altough i exported using lower fields)
    When i use the DV PAL codec everything is fine.
    am I missing something?
    Thanks in advance
    Ronald
    Ronald replied 19 years, 3 months ago 2 Members · 2 Replies
  • Michiel
    May 14, 2007 at 3:36 pm
    you cannot usually play animation codec in realtime unless you have a very fast computer. When you say uncompressed do you mean something like Blackmagic Uncompressed (10bit) codec? What kind of video hardware are you using? Are your sequence settings corresponding to the material? You can set the correct field order for FCP by ctrl-clicking on a clip in the bin, then item properties – format. If you exported lower field from AE, it should say lower field in FCP as well and your sequence should be lower field too obviously.
  • Ronald
    May 15, 2007 at 7:57 am
    I found the solution.
    Final Cut was using the shift field filter for some strange reason.
    When I remove the filter the clips play fine.
    Thanks, Ronald
