Activity Forums Apple Final Cut Pro Legacy Field order when you media manage
  • Field order when you media manage
    Posted by Pasi Koivisto on December 8, 2010 at 5:50 pm
    Hi all, I just need to double check something. I think it’s a happy surprise.
    I have a DV-pal sequence that I media managed to SD Uncompressed and it looks like Final Cut not only changed the codec but also the field order. (DV-pal is lower field and SD-Pal uncompressed is upper field). Is this how it works now?
    I was kind of set on having to apply a shift-fields filter to everything it looks like I am not going to have to do this. I know, RTFM but my client is going to be here in like 30 minutes and I wanted to conform my findings.
    As always
    Pasi
    Pasi Koivisto replied 15 years, 8 months ago 2 Members · 2 Replies
  • Rafael Amador
    December 8, 2010 at 7:31 pm
    [Pasi Koivisto] “I have a DV-pal sequence that I media managed to SD Uncompressed and it looks like Final Cut not only changed the codec but also the field order. (DV-pal is lower field and SD-Pal uncompressed is upper field). Is this how it works now?”
    That’s the proper way. PAL Uncompressed 8/10b standard uses Upper First field order.
    FC would get messed up with a Lower First 8/10b Unc file.
    rafael
    http://www.nagavideo.com
  • Pasi Koivisto
    December 8, 2010 at 9:39 pm
    Yes, I know that. What I wanted to confirm was that the field order was fixed when you media manage. Something I haven’t seen before.
    /Pasi
    Editor, Colorist.
    Mac Pro, 8×3 Ghz, 8 Gb ram, ATI Radeon HD 4870, KONA 3, Sony PVM20L4, Tangent Devices Wave.
