Field Order unchangeable?
I’ve been rendering videos to m2ts using the Sony AVC/MVC template AVCHD 1920×1080-60i. Recently, after changing the Field Order in the project properties to avoid interlacing on my videos, I noticed that everything looked fine until I started rendering and I would see interlacing in the video preview during rendering. I could not figure out what was going on for a few months, but a few days ago I noticed that when I check Customize Template in the render window Field Order shows “Upper field first” and is greyed out, so I assume this is overriding the project preferences.
If I switch the file extension to MP4 in the system tab I can change the field order to match my preferences (it’s no longer greyed out) but why would my project preferences be overridden by this particularly?
