Activity Forums Blackmagic Design Field-order swap on MBE SD output through DVI-D
  • Field-order swap on MBE SD output through DVI-D
    Posted by Adam Levine on June 8, 2006 at 4:47 pm
    FINALLY got around to getting an HD monitor to go with my MBE. Went with the Sony consumer CRT model (34XBR970). I have the MBE going through the DVI-D output to the HDMI adapter, to HDMI cable to HDMI port on the monitor. HD looks PHENOMENAL. SD looks decent, but I am getting reversed fields when I playback. The playback on my SD monitor (Sony 20L5 via component) is perfect (Blackmagic NTSC DV easy setup)
    I am going to troubleshoot later today, but I have a client coming in soon and I was wondering if there was a quick fix?
    Kristian Lam replied 20 years, 2 months ago 2 Members · 5 Replies
  • Adam Levine
    June 8, 2006 at 5:53 pm
    Also:
    DVI-D-> HDMI cable exhibits the same problem
    Composite output is fine. Will check component later
    I would prefer to use the DVI-D port for this monitor for all uses if possible
  • Adam Levine
    June 9, 2006 at 7:20 pm
    Well, it seems that the problem only exists over the DVI-D port, and only with DV (720×480) footage. When I drop the footage in a 720×486 seq, all plays back fine after render. So, it seems that the DVI-D output does not adjust for the missing 6 lines properly.
    BMD, anything that can be done about this with a software upgrade?
    Just to sum up the problem, the field order is wrong when playing back DV-NTSC material through the DVI-D output on the MBE. Thanks
  • Kristian Lam
    June 13, 2006 at 4:31 am
    Hi Adam,
    Thanks for the report. We’ll look into it. As I recall, you’re on a Mac right?
    regards
    Kristian Lam
    Blackmagic Design
  • Adam Levine
    June 13, 2006 at 4:35 am
    Yes, that’s right.
    G5 Quad, MBE, OS 10.4.6, BM 5.5.1, FCP 5.1
  • Kristian Lam
    June 21, 2006 at 2:03 am
    Hi Adam,
    We’ve tested this with the latest driver and it’s fine. May I suggest upgrading to that driver (v5.6.1) which you can find on our site here:
    https://blackmagic-design.com/support/software/
    regards
    Kristian Lam
    Blackmagic Design
