Activity Forums Broadcasting Field Order Confusion – Any Advice!
  • Field Order Confusion – Any Advice!
    Posted by Mark Vernon on February 11, 2008 at 11:03 am
    Wondering if anyone can offer any advice in relation to the world of field order.
    I have recently spent some time learning about the importance of field order throughout production but I am confused as to what is the right thing to do in the situation of converting from DV footage (which I understand is lower field first) to a SD PAL file prepared for broadcast (which I understand is upper field first).
    At what stage do I swap fields?
    Should I swap fields?
    Won’t this lose me quality?
    I produce low buget commercials on a regular basis but used to supply to the station on Mini DV, they would do the rest.
    Now trying to improve workflow and quality we have started using dubsat mpeg2 distribution and just had problems with interlacing.
    This is my first time on the cow and any advice would be greatly appreciated.
    Mark Vernon replied 18 years, 7 months ago 1 Member · 1 Reply
  • Mark Vernon
    February 20, 2008 at 8:26 am
    Thanks for the advice Dave.
    I think I do have the field order nailed at the moment for after effects/premier ads when there is no actual filmed footage, I just always render everything upper field first and seem to go through the system ok.
    My question now is when I next do a commercial (or any video project) that has filmed footage on my dv camera, do I create a upper field first project in premier and capture my footage this way or do I capture it in a lower field first project and drop it into an UFF project?
    To many options???
    As for just using progressive, this seemed to create problems with the broadcaster as it’s only a SD broadcast snd dubsat also are not yet accepting high def files, and although a great service, when asked for mpeg setting they were VERY breif!
