field order blackmagick
hello.
how can I control field order in source code?
if you run a “sample code” application from developer.apple.com called “SimpleVideoOutput X” and select decklink pro board(you need a board of course :O) 8 bit and PAL and select a DVSTREAM sequence and also select high quality in the pop up menu you will have wrong field order on the video output???
but if you select the same sequence from FCP it will playback correct…
what is FCP doing to make it right?
one solution would be to shift output picture one pixel down or up, on the output signal, but I cant imagine HOW to do it….
need help…
regards…
svante
