Activity Forums Blackmagic Design Field Order
  • Field Order
    Posted by Rikk Desgres on April 10, 2014 at 7:11 pm
    For the first time in a while (and since I had the Intensity Pro) I’m working on a program in SD. I decided to hitch my analog component monitor up. The output of the Intensity Pro sometimes has it’s field order reversed. What I mean by sometimes is I can play the timeline and it’s fine, stop, then start again and it’s revered. So there is a 50/50 shot if the field order will be revered or not. This happens exactly the same from Final Cut v7 or Pro Tools 11. I’m using Desktop Video 9.7.5 which is the latest one which will work with Pro Tools 11. Mac OS 10.8.5.
    Any ideas?
    Rikk Desgres replied 12 years, 5 months ago 1 Member · 0 Replies
  • 0 Replies
