Field order
Posted by Blue.eagle on June 1, 2005 at 2:29 pmhi all,
is there any utility/software that enable to know the field order of a avi dv file?
ThanksBlue.eagle replied 21 years, 3 months ago 3 Members · 8 Replies -
Blue.eagle
June 1, 2005 at 3:03 pmNot the Pal AVI Matrox dv codec.
My question was about to know the field order because Vegas interprets a Matrox avi files as a Lower Filed first, but I’m sure it’s a Upper Field.
Any idea? -
Bill Ravens
June 1, 2005 at 3:26 pmIf you open an AVI file in the Vegas Media Pool, and look at the detailed view, it will tell you whether the file is upper or lower field first.
Blue.eagle
June 1, 2005 at 3:39 pmOk but could it be possible that vegas do not interpret in the correct way the matrox pal dv codec that it is always UPPER ?
Blue.eagle
June 1, 2005 at 3:52 pmno…Pal is always lower, only avi captured by Matrox RTX100 is Upper, but Vegas seams to interepret it as a lower….and I don’t know the reason
Bill Ravens
June 1, 2005 at 4:09 pmwhether a file is encoded as upper field first or lower field first, the way software knows which is set by a data bit in the AVI header. if the bit is set incorrectly, obviously application software will read the wrong value. there is some software available that allows you to reset the data bit in the header.
