Activity Forums Panasonic Cameras Field Offload to Windows When Final Destination is FCP
  • Field Offload to Windows When Final Destination is FCP
    Posted by Val Boyd on February 2, 2012 at 4:22 pm
    I’m going to be doing a lot of interviews in the field and will need to offload the P2 cards as I go. I have a windows based laptop I can use but I edit on Final Cut. Are there any issues I should be concerned about? I know that Mac and Windows often don’t play nicely together.
    Val Boyd replied 14 years, 7 months ago 2 Members · 2 Replies
  • Shane Ross
    February 2, 2012 at 6:18 pm
    No…no worries at all. P2 cards are Fat32 based, and have the same file size limitations as PC drive formats. Just format your offloading drive as Fat32….and backup the cards. Then connect the drive to the Mac and Log and Transfer.
    Many of my shooters use PCs for field offloads.
    Shane
    Little Frog Post
  • Val Boyd
    February 2, 2012 at 7:00 pm
    That’s what I thought, but I wanted to make sure… Many thanks!
