Activity Forums Apple Final Cut Pro Legacy Field mush in source clips
  • Field mush in source clips
    Posted by Stanomatic on June 9, 2006 at 4:18 am
    How do I avoid the field mush problem when editing graphics rendered as quicktime clips. I don’t beleive I resized the clip when bringing it into Final Cut Express. Did Final Cut resize it automatically?
    Todd Gillespie replied 20 years, 3 months ago 2 Members · 1 Reply
  • Todd Gillespie
    June 9, 2006 at 5:06 am
    FCE will resize your graphics usually depending on the size and ratio, you can check in the motion tab under scale.
    For a lot of graphics you might need to apply Video-flicker filter. Sometimes it’s an interlacing issue.
    You might need to explain your issue with a little more detail and better discription than ‘mush’
    Good Luck,
    Todd at UCSB
    Television Production
