Activity Forums Broadcasting field monitors
  • field monitors
    Posted by Jim Mulleder on August 4, 2005 at 11:14 pm
    Howdy cowsters and video pros,
    I am looking at some field monitor options that use regular rechargeable batteries. I am looking for a SD (but could have HD) monitor that will run on Nickel Metal Hydride double A’s or simliar. It would be a plus if the monitor had a power adaptor option to act as a program monitor for my camera on a multi-cam sports mobile.
    Any thoughts???
    Cheers
    Jim
    Jim Mulleder
    Techical Producer
    https://www.telestudios.ubc.ca
    Bob Pennington replied 21 years, 1 month ago 2 Members · 1 Reply
  • Bob Pennington
    August 5, 2005 at 5:48 pm
    Jim: Most of the monitors with a nice resolution usually draw current that requires larger rechargeable batteries. Anton/Bauer offers 14.4 volt batteries that handle the power draw for most professional batteries. If you are intersted in powering small 7.2 volt cameras, we offer Gold Mount (Anton/Bauer) battery mounts that have a voltage converter built in so you can power your 7.2 volt camera with a 14.4 volt battery.
    https://www.antonbauer.com/7_14_gold_mounts.htm
