Activity › Forums › Panasonic Cameras › Field Monitor Advice
  • John Fishback
    August 6, 2008 at 2:17 pm
    A lot depends on what you need the monitor to do. For critical monitoring by our video engineer we use the Panny BTLH1700W. However, for client and director monitors we use less expensive 8″ V-LCD8Pro Marshall SD LCDs (the HD is downconverted in the camera).
    John
    Dual 2.5 G5 4 gigs RAM OS 10.4.8 QT7.1.3
    Dual Cinema 23 Radeon 9800
    FCP Studio 5 (FCP5.1.4, DVDSP4.1.1, Comp2.3, STP1.1, Motion 2.1.2)
    Huge U-320R 1TB Raid 3 firmware ENG15.BIN
    ATTO UL4D driver 3.50
    AJA IO driver 2.1 firmware v23-28
    Pro Tools HD w 192 Digital, SYNC IO, Yamaha DM1000, Millennia Media HV-3C, Neuman U87s, Genelec Monitors, PrimaLT ISDN
  • Vince Becquiot
    August 6, 2008 at 3:45 pm
    We use a BT LH1760 (the 1700 has a green tint that is very hard to get rid off, if even possible)
    Well worth the money IMO and has some improvements over the 1700. Mainlely, fanless, 120hz refresh rate (gets a bit flickery though), and an SDI vectorscope (waveform still works for component), and more buttons to get to features. You won’t be able to mount on the camera of course, but you can buy a frame that adapts to a C-stand.
    The bonus for that size is that you can also use it for editing if you want.
    Vince
  • Rennie Klymyk
    August 6, 2008 at 4:29 pm
    Seems to me the newer BT LH1760 also has a zoom feature that lets you display a section of your image at native 1920X1080 resolution, pixel for pixel which has to be nice for critical focusing. I think one of the new smaller pany monitors also has this feature. I seem to recall the 1760 has HD-SDI built in also whereas on the 1700 it was an option. I’m just going by memory here from reading the intro when the monitor was 1st released so be sure to confirm these points on the pany web site. Seems like a awesome monitor suitable for field and/or edit suite.
    “thou can not stir a flower without crumbling a star” ……Henry Wadsworth Longfellow
  • Michael Sacci
    August 9, 2008 at 3:32 am
    check closely the video inputs, remember the HVX only has component out.
