Hello Logan and welcome to the Cow Audio Forum.
If you’re not the audio guy, are you certain the ntg-2 is the right mic for the job?
If you’re shooting inside a normal residential or industrial/commercial space with 8′ ceilings, you don’t want an interference tube mic like a shotgun. You want a smaller supercardioid or hypercardioid.
The audio sections of RED cameras vary significantly depending on which “build” was used. RED was clueless about audio when they came to market with their camera. As a result, getting audio into them can be problematic. Most early REDs only take -10 dB input instead of 0 or +4 professional levels. The RED uses TA3 input jacks rather than XLRs and in early versions the pin outs of the jacks were not industry standard. There were noise issues due to the loud cooling fans that were mitigated to some degree when they changed the firmware to turn fans off when in RECORD, but that meant the sound person listening for local ambient noise could only get a good listen when the camera was recording.
If Sony, Panasonic or Canon had brought a camera like that to market, they would have been spanked really hard by the reviewers.
Only one mic? Well if you find out if the camera will take professional line level. Then the Sound Devices MixPre is a good choice.
More expensive than you want, but you need to get through the sticker shock to get to the good stuff. In fact, if you’re really serious about your gear, the entry level mixer I spec for clients is the Sound Devices 302. It can be switched to either mic or line level output.
Regards,
Ty Ford
Want better production audio?: Ty Ford’s Audio Bootcamp Field Guide
Watch Ty play guitar
