Activity Forums Adobe Premiere Pro Field issues with 1080i & 1080p on same timeline…
  • Field issues with 1080i & 1080p on same timeline…
    Posted by Harjite Dosanjh on February 8, 2013 at 4:26 pm
    Hi Guys,
    Need some advice with the following issue.
    I have footage captured form a Sony Z1 and from a Canon 5D MKII. My Sony footage is 1440x1080i and my Canon footage is 1920x1080p.
    Im using Premiere Pro CS5.5 for editing.
    When I export the footage and burn with Encore I am have field issues. I have tried many things to remove this issue but nothing is working? I have tried to change the 1080p footage to upper field but no luck.
    Has anyone ever work with these different element and managed to burn a blu ray without any field issues?? If so pleas could you share how you did so?
    Many thanks in advance!
    Harjit Dosanjh
    Harjite Dosanjh replied 13 years, 7 months ago 2 Members · 2 Replies
  • Bernhard G.
    February 9, 2013 at 1:32 pm
    Hello,
    my tip would be to copy everything from Your sequence
    into a 1920×1080/p sequence with double frame rate.
    You’ll need to activate frame blending for every 1080p clip to interpolate
    the missing frames!
    Let AME convert back to 1080i.
    At the moment, PremierePro‘s de-interlacing and motion change processing can’t be assumed as ‘professional’
    (CS6 the same as CS5.5).
    So PLEASE don’t forget to write Adobe a feature request for
    motion-compensated de-interlacing and motion analysis for speed changes!
    They are listening.
    Best regards,
    Bernhard
  • Harjite Dosanjh
    February 11, 2013 at 2:13 pm
    Hi Bernhard,
    Thanks for your reply mate, I will give it try and see how I get on!
    Harjit
