Activity › Forums › AJA Video Systems › Field issue on recorded tape
  • Field issue on recorded tape
    Posted by Christopher Tay on December 27, 2007 at 10:52 am
    Is there a chance where a messed up sequence setting would cause a recorded tape to have field one from the previous clip and field two from the next clip on a cut point ?
    For example, if my clips are DV NTSC (lower field) and I force my sequence to work in upper field, would it have any effect on which field (1 or 2) on the cut point when edited to tape ?
    -chrispy
    Tom Brooks replied 18 years, 9 months ago 3 Members · 2 Replies
  • Arnie Schlissel
    December 27, 2007 at 4:03 pm
    [Christopher Tay] “if my clips are DV NTSC (lower field) and I force my sequence to work in upper field, would it have any effect on which field (1 or 2) on the cut point when edited to tape ?”
    If you put DV into an upper field first timeline without using the shift fields filter, then your field order is indeed wrong.
    What format are you trying to output to? Most SD NTSC is lower field first.
    Arnie
    Now in post: Peristroika, a film by Slava Tsukerman
    https://www.arniepix.com/blog
  • Tom Brooks
    December 28, 2007 at 1:14 am
    Yes, it’s definitely wrong and would cause stuttering motion. But would it cause a VTR to edit on Field2? My guess is no. I’m not sure what difference it would make at that point, though, as the motion scenes would be very ugly.
    I’ll have to defer to someone with more knowledge of field dominance (as opposed to field order as determined by FCP). I think the VTR would still cut on the correct field as proscribed in the particular DV video standard.
    To further complicate things, it might be possible to set the VTR to edit on the non-standard field.
