Activity Forums Apple Final Cut Pro Legacy Field issue editing 8-bit uncompressed
  • Field issue editing 8-bit uncompressed
    Posted by Ross Marshall on January 16, 2008 at 8:36 pm
    Hi working in PAL mode editing a documetary using codec 8 bit uncompressed. The footage was mainly shot on digibeta. However there is also some footage on DV pal which when put on timeline there is a field issue. My question is what feild dominance should I work with. Does digi beta work with upper field or lower field. Thanks in advence.
    Ross
    Neil Ryan replied 18 years, 7 months ago 2 Members · 1 Reply
  • Neil Ryan
    January 16, 2008 at 11:23 pm
    I PAL, all codecs are Upper Field except the DV codecs, which are Lower field.
    Neil.
    Neil Ryan
    Post Production
    The Pod Multimedia
    http://www.the-pod.com.au
