Activity Forums Apple Final Cut Pro Legacy Field dominance settings
  • Field dominance settings
    Posted by Andreas Eidhagen on March 30, 2009 at 7:47 am
    Capture presets in final cut pro:
    Hi, im using Kona3 together with final cut pro and when working with progressive footage we set the timeline setting to field dominance none. However, this seems to be causing some problems with jagged edges in some of the footage.
    I guess the reason for this is that when we capture the footage it’s in field dominance Upper (odd) and when we drop it in a timeline that’s set to field dominance none it de-interlaces the footage.
    Since we have to work with a no field-dominance setting in the timeline in order to get dissolves progressive we were wondering how to capture (what AJA settings should we use in the Audio/Video settings) so that the quicktimes in final cut pro are set to field dominance none as default.
    We are working with PAL 25fps both and HD 25 fps. I would like to send some screenshots to better illustrate my point but doesn’t seem to be possible in this forum.
    / Andreas Eidhagen
    Robert Eidschun replied 17 years, 3 months ago 7 Members · 17 Replies
  • 17 Replies
  • Stephan Walfridsson
    March 30, 2009 at 2:07 pm
    Are you seeing the jagged edges on an external monitor or only in the canvas viewer?
    [Andreas Eidhagen] ” when we capture the footage it’s in field dominance Upper (odd) and when we drop it in a timeline that’s set to field dominance none it de-interlaces the footage. “
    So if you change the field dominance setting to ‘none’ for the source footage in the fcp browser, does that solve your problem?
    [Andreas Eidhagen] “We are working with PAL 25fps both and HD 25 fps.”
    Do you mean the you have both HD and SD on the same timeline? What is your sequence set to SD or HD? Is the problem occuring on SD or HD footage or both?
    Stephan
  • Andreas Eidhagen
    March 30, 2009 at 2:32 pm
    Both (if i make a quicktime export it’s there as well no matter what codec i use.)
    [Andreas Eidhagen] ” when we capture the footage it’s in field dominance Upper (odd) and when we drop it in a timeline that’s set to field dominance none it de-interlaces the footage. ”
    Yes, that solves the problem. However, I have to drop the clip to the timeline.
    No, sorry, what I mean is that the problem occurs both in HD and SD. I have one timeline that’s HD with 1920*1080 footage + one timeline that´s SD with 720*576 anamorphic footage and the problem is the same.
    How do you work with progressive footage, do you set your field dominance to none in the timeline? Or do you work with field 1 (upper)? Do you know if it’s possible to have the field dominance set to upper in the timeline settings but still render dissolves as progressive instead of interlaced?
    / Andreas
    Stephan
  • Jeremy Garchow
    March 30, 2009 at 5:04 pm
    [Andreas Eidhagen] “How do you work with progressive footage, do you set your field dominance to none in the timeline? Or do you work with field 1 (upper)? Do you know if it’s possible to have the field dominance set to upper in the timeline settings but still render dissolves as progressive instead of interlaced? “
    OK. If you can remember, what you need to do is set your clips right after you capture to a field dominance of none in the browser, then you add these clips to a none timeline. If you have already begun your edit, you should still change the clips in the browser to none for future edits (you can do more than one at a time by selecting them and right clicking on the field dom column), but more importantly, for the clips already in the timeline, you need to select all in the timeline, then right click on a clip and choose Item Properties > Format. Then find the row that says ‘Field Dominance’. You will have to change them all to None one by one, but it will be easier than reediting them all in to your timeline.
    Make sense?
    Jeremy
  • Andreas Eidhagen
    March 31, 2009 at 7:36 am
    Hi, makes perfect sense, that’s the way we are working with the footage right now. The problem is that when working with a commercial that has 10 different edits and you already have a short deadline this solution becomes extremely time in-sufficent. There has to be a way to either get the clips set to none in field dominance as a default or to render the dissolves as frames instead of fields even though the timeline settings are set to upper (odd).
    Also, we are doing a 2 hour feature in a short while and changing the item properties for all those clips just isn’t an alternative.
    / Andreas
  • Michael Gissing
    March 31, 2009 at 7:48 am
    I am sure the broadcasters for the commercials will want an interlaced final for the HD and SD is only interlaced so I am not sure why you are working with a ‘none’ timeline.
    Your SD was surely shot interlaced but what about the HD?
  • Andreas Eidhagen
    March 31, 2009 at 7:56 am
    Well, the commercials are shot on 35 then telecined to either HD or SD (HDSR or Digibeta). We want them in full frames (progressive) since there both for cinema and TV.
  • Michael Gissing
    March 31, 2009 at 8:42 am
    [Andreas Eidhagen] “the commercials are shot on 35 then telecined to either HD or SD (HDSR or Digibeta)”
    So the source material is psf, which is an interlaced frame with progressive segmented fields if you are at 25 fps on the HDCam SR.
    The digibeta is also progressive in an interlaced frame, so I still don’t understand why you don’t use 1080 50i for HD and uncompressed SD because that’s what you have on tape. In each case you are upper field dominant
  • Andreas Eidhagen
    March 31, 2009 at 11:19 am
    ______
    I use uncompressed SD and 108050i but the problem is that if i work in a timeline with Upper field as dominant the transitions are interlaced! With other words, printed out to a film copy looks like shit. If i could work with upper field as dominant but render the transitions as full frames instead of fields then the problem would be solved but no one seems to know how or if this is possible.
  • Walter Biscardi
    March 31, 2009 at 11:21 am
    [Andreas Eidhagen] “If i could work with upper field as dominant but render the transitions as full frames instead of fields then the problem would be solved but no one seems to know how or if this is possible. “
    I don’t believe that’s possible. Your timeline is interlaced. Transitions will be the same as the timeline.
    Walter Biscardi, Jr.
    Biscardi Creative Media
    HD and SD Production for Broadcast and Independent Productions.
    Read my Blog!
    STOP STARING AND START GRADING WITH APPLE COLOR Apple Color Training DVD available now!
  • Andreas Eidhagen
    March 31, 2009 at 11:25 am
    That’s pretty much what I thought, but how do people work with a project thats shot on 35, scanned and graded to a HDSR and then onlined and back to HDSR and film? What’s the typical workflow in final cut?
    / Andreas
