Activity › Forums › Apple Final Cut Pro Legacy › Field dominance question – DV = lower/even field – Pal STD = upper/odd field…?
  • Field dominance question – DV = lower/even field – Pal STD = upper/odd field…?
    Posted by Justin Tan on September 5, 2006 at 6:09 am
    Hey guys,
    I hope this hasn’t been asked before( as it seems like an obvious problem) as I was not able to find anything using search…
    I recently received something that came from DV source. It was captured, edited and then provided to me as one big DV file.
    The problem is that when I take it into FCP and play it out to a Digi (they required this as a deliverable) it was one field out – IE it looked ok, but on each cut you would see half of the previous frame.
    anyone have any tips on how I could fix this?
    thx,
    JT
    Martin Baker replied 20 years ago 2 Members · 1 Reply
  • Martin Baker
    September 5, 2006 at 9:13 am
    Yes it is a field dominance problem because you’ve got cuts happening on field 2 rather than field 1. Confusingly this is not connected with FCP’s (incorrectly labelled) Field Dominance setting though which is really Field Order – the order of the fields within the same frame.
    This is the only fix I know of:
    https://www.joesfilters.com/joes_field_fixer
    Martin
    Digital Heaven, London UK
    Unique plug-ins and tools for Apple Pro Apps
    NEW! BigTIme – resizable timecode display for FCP
