Activity Forums Apple Final Cut Pro Legacy Field Dominance Anomaly with DNxHD codec recompress vs import
  • Field Dominance Anomaly with DNxHD codec recompress vs import
    Posted by Andrew Johnson on March 20, 2013 at 3:00 pm
    I am trying to combine some DNxHD 36 8 bit footage which I’ve run though Pavtube HD Video Converter on a PC into Final Cut Pro sequences which I have cut in Pro Res 422 and then re-compressed into the same codec through Media Manager on FCP 7.
    The DNxHD 36 8 codec is not available ‘native’ in the recompression route through media manager but is selectable in the Quicktime video settings of the sequence settings window.
    The clips I get from the internal compression setting on FCP using this saved sequence preset maintain Field dominance (Odd) whereas my DNxHD 36 8 clips from the PC are Field dominance (None) when I drag them across to fcp, despite my setting the field dominance on the sequence settings to field dominance (none).
    I can’t combine these clips in the same sequence without rendering and for an 80-minute sequence this is totally impractical.
    What am I doing wrong?
    Rafael Amador replied 13 years, 5 months ago 3 Members · 10 Replies
  • 10 Replies
  • Rafael Amador
    March 20, 2013 at 5:05 pm
    If you are sure that the footage is Progresive, check it as NONE on the Browser.
    Rafael
  • Jeff Greenberg
    March 27, 2013 at 11:51 am
    Andrew, it’s not you. It’s Apple.
    [Andrew Johnson] “The DNxHD 36 8 codec is not available ‘native’ in the recompression route through media manager”
    Apple doesn’t permit it. Period.
    They also don’t see DNxHD as a YCr’Cb’ codec, but rather as an RGB codec.
    [Andrew Johnson] “The clips I get from the internal compression setting on FCP using this saved sequence preset maintain Field dominance (Odd) whereas my DNxHD 36 8 clips from the PC are Field dominance (None) when I drag them across to fcp, despite my setting the field dominance on the sequence settings to field dominance (none).”
    FCP isn’t paying attention to the clips period.
    [Andrew Johnson] “I can’t combine these clips in the same sequence without rendering and for an 80-minute sequence this is totally impractical”
    Couple of thoughts. However you’re getting the DNxHD files…could you get something else? Or transcode before using FCP7 (this is the most common workflow.)
    Beyond that? Nothing good as a suggestion – only use a different NLE (Avid, Premiere Pro or FCPX.) None of the three need transcoding for playback.
    Best,
    Jeff I. Greenberg
    Author/Master Instructor/Speaker/Consulting
    My contact info and more
    New! Come see me speak @ NAB/Post Production World!
  • Andrew Johnson
    March 28, 2013 at 10:38 am
    Thanks for this response. I have tried multiple other formats that Pavtube HD Video Converter on the PC gives me as transcoding options and none of them behave in FCP as a true NLE codec should. Most of them are not editing codecs.
    Basically, I’m trying to dodge proprietary .264 files from real security cameras into something I can edit in FCP on a found footage feature film.
    The—immeasurably cumbersome—Mac workaround is to play them through the proprietary .264 player from the manufacturer of the cameras and Camtasia the full screen as a Pro Res 422 file, but this takes an absolute aeon, and introduces latency when other processes are going on in the operating system (literally) in the background.
    I’ve gone too far down the road of the assembly cut of the feature (1 hr 20mins so far) to switch to AVID or Premiere now and I dearly want to set the separate PC I’ve just bought (i7, GTX 650 1GB GDDR5, 16GB RAM) to work on transcoding these .264 files while I get on with the rest of the edit.
    The last resort option I can see is to convert the .264s into AVIs with AVI Generator 9.0 and then transcode them into DNxHD on Pavtube HD Video Converter but we’re going one generation down then, aren’t we, which is not desirable.
  • Jeff Greenberg
    March 28, 2013 at 1:54 pm
    How about you try this FFMPEG encoder that can build ProRes or DNxHD?
    If this doesn’t work, could you please post a link to AVI Generator, because I’ve never seen it before.
    Best,
    Jeff I. Greenberg
  • Rafael Amador
    March 28, 2013 at 2:45 pm
    You can try as well to convert the camera files to AVI/Animation. Then the files could be rewrapped as QT/Animation. Rewrapping is fast and doesn’t degrades the picture.
    Other solution would be to export the movie as an stills sequence.
    rafael
  • Andrew Johnson
    March 28, 2013 at 3:33 pm
    Well, the specs on the website for that FFmpeg encoder certainly look like we’re in the right area. I’m going to try it now.
    AVI Generator takes the proprietary .264s and spits them out as .avi and it was on the disc which came with the security cameras we bought. Try this and follow the link to ‘AVI Generator’.
    with the specs on my PC (i7, GTX 650 & 16GB RAM) the conversion happens remarkably quickly, but the resulting images are soft as hell.
  • Andrew Johnson
    March 28, 2013 at 5:52 pm
    If I go to AVI I lose a generation and I don’t want any loss.
    The only video converters I have found so far which will actually deal with the .264 files are Pavtube HD Video Converter and Cinec (which is an FFmpeg program) on the PC and nothing on the Mac will even play these .264s, nor convert the .avi files I get when I convert the .264s to .avi in AVI Generator on the PC. Compressor won’t even look at the .avi files I have obtained from AVI Generator on the PC which seems baffling to me, especially when I have installed everything to do with DivX and 3ivx onto the Mac running Compressor.
    I think some of this incredible bottleneck could be due to the possibility that the .264s I have shot might be raw video streams rather than containerised clips.
    The bonus with Cinec on the PC is that it theoretically spits out Pro Res 422 files straight from the .264s on the PC natively, which is exactly what I need, but the cinec.lib1.exe crashes whenever the converted file gets to about 9 gigs, whether I’m using one core or two and regardless of what drives I’m running it off.
    I surmise this is because of the protection issues around the Apple codecs, or the streaming issue, or the bad coding of Cinec, but I’m about ready to hurl this godforsaken PC lemon into the street as I can’t get even one decent file from any of this mindless trial-and-error ludicrousness.
  • Jeff Greenberg
    March 28, 2013 at 6:37 pm
    My day has gotten crazy, but here are some quick ideas
    Try DNxHD in cinec. Get something out (without it crashing) Try different prores flavors too.
    There’s FFMPEGBC (Broadcast). Try a command line version. Try a GUI for it: https://www.stuudio.ee/anothergui/
    If it’s a file named 264, its gotta be a h264 stream. Maybe a re-wrapper will work (and then a conversion)
    Last, could you run Media Info on the 264 file (or better yet post one for me?) – I’d like to see one.
    [Andrew Johnson] ” I surmise this is because of the protection issues around the Apple codecs, or the streaming issue, or the bad coding of Cinec, but I’m about ready to hurl this godforsaken PC lemon into the street as I can’t get even one decent file from any of this mindless trial-and-error ludicrousness.”
    No protection around ProRes…but it’s been shoehorned into FFMPEG – so who knows what’s been done there. I don’t know about the coding of Cinec.
    Don’t blame the PC – it’s the stream your struggling with. Call the company and give them a piece of your mind!
    (But seriously, can you give me a small file so I can look at it?)
    Best,
    Jeff I. Greenberg
  • Andrew Johnson
    March 29, 2013 at 6:50 pm
    Okey doke, thanks for this.
    Here’s an avi from AVI Generator of the same .264 which I converted from a .264 into a DNxHD 36 .mov in HD Video Converter here (see 6.49mins in) and I’ve uploaded the shortest .264 I can find in the whole cache for speed of use.
    The Media Info of a typical example of one of these .264 files is as follows:
    General
    Complete name : C:DAY 06ch00000000000001-130220-133704-135106-00p00001000000400.264
    Format : AVC
    Format/Info : Advanced Video Codec
    File size : 202 MiB
    Video
    Format : AVC
    Format profile : Baseline@L3.0
    Format settings, CABAC : No
    Format settings, ReFrames : 2 frames
    Format settings, GOP : M=1, N=25
    Width : 704 pixels
    Height : 576 pixels
    Display aspect ratio : 1.222
    Standard : PAL
    Color space : YUV
    Chroma subsampling : 4:2:0
    Bit depth : 8 bits
    Scan type : Progressive
  • Rafael Amador
    April 2, 2013 at 11:35 am
    The first thing i would do is to try deleting the “.264” extension.
    Seems that is common on CCTV files, but i don’t think will help on a Mac.
    Then you can try to open the file with QT Player.
    If doesn’t works, try installing Perian (free).
    If still not opening, try with ClipWrap. They have a free trial version.
    TW, when you make the conversion, check the footage as Progressive.
    Whatever FC may say.
    rafael
