Activity › Forums › Apple Final Cut Pro Legacy › Field dominance
  • Field dominance
    Posted by Zeke Meginsky on July 12, 2011 at 5:10 pm
    I was wondering if it’s neccessary that the field dominance in my sequence be set to Lower Field. I use DV footage, but I’m also importing After Effects animations that have no field dominance. Would the DV footage be negatively affected if I set the sequence for no field dominance? Would there be a reason I should do this?
    Should I set the After Effects animations to lower field first? Does that make a difference in the quality or will it look the same as with no field dominance (if the sequence was set for lower field)? It’s eventually going to be on a DVD (probably not an HDVD).
    Zeke Meginsky replied 15 years, 2 months ago 1 Member · 1 Reply
