Activity Forums Apple Final Cut Pro Legacy Field dominace in Panasonic HS400 Switcher.
  • Field dominace in Panasonic HS400 Switcher.
    Posted by Steve Cohen on June 10, 2011 at 1:37 pm
    I’m not an engineer, so forgive me if this is wrong.
    I think my studios Panasonic AV-HS400 switcher is set to the wrong field.
    I’m not sure where to find that, but i was looking thru the manual for it an I found a section that talks about cross points, in there they refer to Crosspoint Switch.
    I just want to confirm that Field2 equates to Even or Lower Field on the Final Cuts.
    Is this correct?
    Thanks for the help.
    Steve Cohen
    Steve Cohen replied 15 years, 2 months ago 1 Member · 0 Replies
  • 0 Replies
