Activity › Forums › Apple Final Cut Pro Legacy › Fibre Channel Cards – The Difference?
Posted by Paco Sweetman on January 14, 2008 at 10:29 amWhat is the difference between the Dual Channel and Quad Channel 4Gb Fibre Channel Cards. What does the difference mean to data transfer and connection to a SAN?
Mark Raudonis replied 18 years, 8 months ago 3 Members · 4 Replies -
Mark Raudonis
January 14, 2008 at 7:37 pmjon,
It’s as simple as you think. Each channel is more through put. Hence, a dual channel card carries twice the data as a single.
The higher the resolution, the more you need this. Example: Even though our G-5’s have “dual Channel” cards, we only have a single fiber cable connecting to the X-SAN. However, we primarily work at off-line resolution, so our bandwidth requirements are low. In contrast, our on-line rooms use BOTH sides of the dual channel card for increased bandwidth.
Mark
Russell Lasson
January 15, 2008 at 1:20 amWith the quad channel card, you could connect two Xserve RAIDs to one MacPro using only one card slot.
-Russ
Paco Sweetman
January 15, 2008 at 1:52 amSo if you used both sides of the Dual Channel card to connect to your SAN, how quick a Data transfer rate would that give you from machine to storage?
Mark Raudonis
January 15, 2008 at 5:41 amYour data transfer rate is dependent upon the speed of your drives, the nature of your “Raid” scheme, and the number of spindles (drives) within the raid.
The raid controller can also add some “overhead” to the load, thereby reducing the transfer rate. Apple has these facts and info on their website. Keep in mind these figures are like gasoline miles per gallon ratings… your mileage may vary.
Mark
