Activity Forums Apple Final Cut Pro Legacy Fiber Channel Shared Network solution for FCP
  • Fiber Channel Shared Network solution for FCP
    Posted by Chris Baldwin on February 9, 2009 at 6:29 pm
    I’m almost ready to pull trigger on updating my edit studio to a fiber channel shared network solution for my 3 G5 towers running FCP(two powerpc and one intelG5).
    The solution I’ve all but settled on is a 12tb version of this https://www.hddglobal.com/FibreDiskS4-16.html
    I’m interested to hear what the Cow community has to say about this type of solution? Any feedback from owners or recommendations to consider instead of this?
    Peter Wiggins replied 17 years, 7 months ago 4 Members · 9 Replies
  • 9 Replies
  • Chris Baldwin
    February 9, 2009 at 7:13 pm
    Just to fill in any gaps…
    I mostly edit DVCProHD content. Multiple streams per project.
  • Chris Borjis
    February 9, 2009 at 7:31 pm
    what are you going to use as a fiber switch and san software?
    I’ve heard that really soon, this is going to become MUCH cheaper
    to do.
  • Chris Baldwin
    February 9, 2009 at 7:34 pm
    I’m not perfectly sure but these are the line items from the quote that apply to your question.
    QLogic SB5600Q08A SANbox 5600 8 Port Switch
    4 Gigabit (4Gb) RoHS Compliant Short-Wavelength SFP Transceiver
    FCDISKS4-12 / 12TB 4Gb FC Raid 2U Rack Mount Cabinet 16 750GB Drives Single
    Controller
    4GB Fibre Channel PCI Express – Dual Port with cables and SFP
    Wiring Diagram
    LC to LC 50/125 micron (Short wavelength) Fibre Cable – 10M
    SANmp Admin/Client- Mac OS X or Windows 2000 and XP
    SANmp Client only – Mac OS X or Windows 2000 and XP
    ATTO CTFC-42XS-0R0 Celerity FC-XS 4Gb Fibre Channel Dual Channel PCI-X Host
    HOW SOON!?!?!?! Yikes!
    I was told that the 8Gb confgs were to come out soon. would this you think drip the 4Gbs?
  • Peter Wiggins
    February 9, 2009 at 7:35 pm
    Is it volume or file based?
    Peter
  • Chris Borjis
    February 9, 2009 at 7:52 pm
    I’m not sure.
    I think Caldigit might be announcing something at NAB.
    significantly lower-cost shared storage is not far off.
    how much is this setup you have quoted? over $ 20,000 ?
  • Herb Sevush
    February 9, 2009 at 8:00 pm
    Chris –
    You should post this on the SANetworks forum. You’ll get your answers there.
    Herb Sevush
    Zebra Productions
  • Chris Baldwin
    February 9, 2009 at 8:08 pm
    yes just under $20k
  • Chris Baldwin
    February 9, 2009 at 8:09 pm
    I’ll do that.
  • Peter Wiggins
    February 9, 2009 at 10:32 pm
    SanMP, so Volume based?
    Peter
