Activity Forums Compression Techniques ffserver + mplayer
  • ffserver + mplayer
    Posted by Giorgio Ascani on March 2, 2011 at 7:49 pm
    I’m trying to use ffmpeg / ffserver to create a RTSP server.
    What I do is:
    $./ffserver -f ffserver.conf
    with the following ffserver.conf:
    #Port on which the server is listening. You must select a different
    # port from your standard HTTP web server if it is running on the same
    # computer.
    Port 8091
    # RTSP Port
    RTSPPort 7654
    # Address on which the server is bound. Only useful if you have
    # several network interfaces.
    BindAddress 0.0.0.0
    # Port on which the server is listening. You must select a different
    # computer.
    RTSPBindAddress 0.0.0.0
    # Number of simultaneous requests that can be handled. Since FFServer
    # is very fast, it is more likely that you will want to leave this high
    # and use MaxBandwidth, below.
    MaxClients 1000
    # This the maximum amount of kbit/sec that you are prepared to
    # consume when streaming to clients.
    MaxBandwidth 1000
    # Access log file (uses standard Apache log file format)
    # '-' is the standard output.
    CustomLog -
    # Suppress that if you want to launch ffserver as a daemon.
    NoDaemon
    Format rtp
    File "/home/marco/Videos/11.mpg"
    Format rtp
    File "/home/marco/Videos/12.mpg"
    Format rtp
    File "/home/marco/Videos/13.mpg"
    And I get:
    marco@marco-virtual-machine:~/Documents/ffmpeg/ffmpeg-0.6.1aaaa$ ./ffserver -f ffserver.conf
    FFserver version 0.6.1, Copyright (c) 2000-2010 the FFmpeg developers
    built on Mar 2 2011 11:53:56 with gcc 4.4.5
    configuration:
    libavutil 50.15. 1 / 50.15. 1
    libavcodec 52.72. 2 / 52.72. 2
    libavformat 52.64. 2 / 52.64. 2
    libavdevice 52. 2. 0 / 52. 2. 0
    libswscale 0.11. 0 / 0.11. 0
    Wed Mar 2 17:53:42 2011 Opening file ‘/home/marco/Videos/11.mpg’
    Wed Mar 2 17:53:43 2011 [mpeg @ 0x92a9720]max_analyze_duration reached
    Wed Mar 2 17:53:43 2011 Opening file ‘/home/marco/Videos/12.mpg’
    Wed Mar 2 17:53:43 2011 Opening file ‘/home/marco/Videos/13.mpg’
    Wed Mar 2 17:53:43 2011 FFserver started.
    Then i try to play the video with mplayer:
    $mplayer rtsp://localhost:7654/11.mpg
    The problem is that mplayer show:
    MPlayer 1.0rc4-4.4.5 (C) 2000-2010 MPlayer Team
    mplayer: could not connect to socket
    mplayer: No such file or directory
    Failed to open LIRC support. You will not be able to use your remote control.
    Playing rtsp://localhost:7654/11.mpg.
    Resolving localhost for AF_INET6…
    Connecting to server localhost[::1]: 7654…
    connect error: Connection refused
    Resolving localhost for AF_INET…
    Connecting to server localhost[127.0.0.1]: 7654…
    A single media stream only is supported atm.
    rtsp_session: unsupported RTSP server. Server type is ‘unknown’.
    STREAM_LIVE555, URL: rtsp://localhost:7654/11.mpg
    Stream not seekable!
    file format detected.
    Initiated “video/MPV” RTP subsession on port 47150
    Initiated “audio/MPA” RTP subsession on port 42762
    Exiting… (End of file)
    and the ffserver show:
    Wed Mar 2 17:55:55 2011 127.0.0.1 – – [DESCRIBE] “rtsp://localhost:7654/11.mpg RTSP/1.0” 200 449
    Wed Mar 2 17:55:55 2011 [mpeg @ 0x92b74c0]max_analyze_duration reached
    Wed Mar 2 17:55:55 2011 127.0.0.1:47150 – – “PLAY 11.mpg/streamid=0 RTP/UDP”
    Wed Mar 2 17:55:55 2011 127.0.0.1:42762 – – “PLAY 11.mpg/streamid=1 RTP/UDP”
    Wed Mar 2 17:55:55 2011 127.0.0.1 – – [TEARDOWN] “rtsp://localhost:7654/11.mpg/ RTSP/1.0” 200 864
    Whats wrong?!?!?!?!?
    thank you in advance
    Giorgio
    Giorgio Ascani replied 15 years, 6 months ago 1 Member · 0 Replies
  • 0 Replies
