Activity Forums Compression Techniques FFserver ain’t stream
  • FFserver ain’t stream
    Posted by Dominik Reider on March 5, 2011 at 4:54 pm
    Hello all!
    Im struggeling here with an issue and i dont get whats wrong.
    First I started FFserver. In another console I typed my ffmpeg command as follows:
    domdom@ubuntu:~$ sudo ffmpeg -an -f video4linux2 -s 640x480 -pix_fmt yuyv422 -i /dev/video0 -f mpeg -b 64 -s 160x128 https://localhost:8090/feed1.ffm
    FFmpeg version SVN-r0.5.1-4:0.5.1-1ubuntu1, Copyright (c) 2000-2009 Fabrice Bellard, et al.
    configuration: --extra-version=4:0.5.1-1ubuntu1 --prefix=/usr --enable-avfilter --enable-avfilter-lavf --enable-vdpau --enable-bzlib --enable-libgsm --enable-libschroedinger --enable-libspeex --enable-libtheora --enable-libvorbis --enable-pthreads --enable-zlib --disable-stripping --disable-vhook --enable-runtime-cpudetect --enable-gpl --enable-postproc --enable-swscale --enable-x11grab --enable-libdc1394 --enable-shared --disable-static
    libavutil 49.15. 0 / 49.15. 0
    libavcodec 52.20. 1 / 52.20. 1
    libavformat 52.31. 0 / 52.31. 0
    libavdevice 52. 1. 0 / 52. 1. 0
    libavfilter 0. 4. 0 / 0. 4. 0
    libswscale 0. 7. 1 / 0. 7. 1
    libpostproc 51. 2. 0 / 51. 2. 0
    built on Mar 4 2010 12:35:30, gcc: 4.4.3
    [video4linux2 @ 0x80a52c0][3]Capabilities: 4000001
    Input #0, video4linux2, from '/dev/video0':
    Duration: N/A, start: 1299340898.718373, bitrate: -2147483 kb/s
    Stream #0.0: Video: rawvideo, yuyv422, 640x480, -2147483 kb/s, 1000k tbr, 1000k tbn, 1000k tbc
    WARNING: The bitrate parameter is set too low. It takes bits/s as argument, not kbits/s
    Output #0, mpeg, to 'https://localhost:8090/feed1.ffm':
    Stream #0.0: Video: mpeg1video, yuv420p, 160x128, q=2-31, 0 kb/s, 90k tbn, 60 tbc
    Stream mapping:
    Stream #0.0 -> #0.0
    Press [q] to stop encoding
    domdom@ubuntu:~$
    As you can see, the command prompt appears directly without any other lines which shows the streaming… And i dont have a stream… Thats what makes me wondering as the same command works if i put a filename instead of the feed. (I used the original ffserver.conf).
    It seems obvious that i missed something, but i dont find anything anywhere in the web…
    Any ideas?? Thanks for help in advance!!
    cheers dominik
    Dominik Reider replied 15 years, 6 months ago 1 Member · 0 Replies
  • 0 Replies
