Activity Forums Compression Techniques ffmpeg: Using -b option with -target pal-dvd
  • ffmpeg: Using -b option with -target pal-dvd
    Posted by Steve Hearn on July 31, 2011 at 2:41 am
    I’m converting a .ts file from a set top box to a mpg file using:
    ffmpeg -i data0001.ts -target pal-dvd data0001.mpg
    Works great. However, the output file is large, so I’d like to sacrifice some resolution to get the size down.
    I tried to use the -b option as follows:
    fmpeg -i data0001.ts -target pal-dvd -b 2048 data0001_2048.mpg
    I do get a smaller file (about 5 times smaller), but quite pixelated. Problem is I get the same size/quality no matter what value I use for -b. That is I tried -b 1024,2048,4096 etc etc and I always get approximately the same output size/quality.
    I dont really have any control over size/quality.
    Am I allowed to use the -target and -b together?
    Steve
    Steve Hearn replied 15 years, 1 month ago 2 Members · 2 Replies
  • Michael Rampe
    July 31, 2011 at 5:09 am
    [steve hearn] ” That is I tried -b 1024,2048,4096 etc etc and I always get approximately the same output size/quality.”
    The -b option is specified in bits.
    Try 1024k, 2048k etc. instead. (1M and 2M also work as do 1024000, 2048000)
    Michael
  • Steve Hearn
    July 31, 2011 at 10:07 am
    Michael
    Thanks very much for your rapid reply. That explains it! I seem to be getting
    much more sensible results now.
    Steve
