Activity › Forums › Compression Techniques › FFMPEG ProRes Export Gamma Shift
  • FFMPEG ProRes Export Gamma Shift
    Posted by Jaemie Manners on October 4, 2012 at 2:57 am
    After exporting via AnotherGUI with the prores preset I’m getting the typical gamma shift noticed in most quicktime files. Is there away to fix this in the command line or am I stuck in doing the work around by modifying the movie properties from within quicktime?
    Any ideas?
    Jaemie Manners replied 13 years, 12 months ago 1 Member · 0 Replies
  • 0 Replies
