Activity Forums Compression Techniques FFMPEG ProRes 422 > How to set custom bitrate?
  • FFMPEG ProRes 422 > How to set custom bitrate?
    Posted by Michal Shipman on November 7, 2013 at 12:49 am
    Hi there, I’m trying to export a trailer for a distributor and they said the bitrate was to small. It had a bitrate of 120mbs and needed to be 160mbs. I’ve a lot of different combinations and I can’t seem to get FFMPEG to use a fixed bitrate.
    Here’s the string I’m using.
    J:>Ffmpeg -i trailer.avs -r 23.976 -codec:v prores -b:v 2000000k -profile:v 2 -codec:a pcm_s16le -filter_complex asetnsamples=n=16384:p=0 trailer6.1920x1080p.p
    rores422.mov
    No matter what I put in for the -b:v command, it seems to default to the normal 200kbs.
    Here’s what the console says:
    ffmpeg version N-57906-gbd75651 Copyright (c) 2000-2013 the FFmpeg developers
    built on Nov 4 2013 18:01:33 with gcc 4.8.2 (GCC)
    configuration: --enable-gpl --enable-version3 --disable-w32threads --enable-av
    isynth --enable-bzlib --enable-fontconfig --enable-frei0r --enable-gnutls --enab
    le-iconv --enable-libass --enable-libbluray --enable-libcaca --enable-libfreetyp
    e --enable-libgsm --enable-libilbc --enable-libmodplug --enable-libmp3lame --ena
    ble-libopencore-amrnb --enable-libopencore-amrwb --enable-libopenjpeg --enable-l
    ibopus --enable-librtmp --enable-libschroedinger --enable-libsoxr --enable-libsp
    eex --enable-libtheora --enable-libtwolame --enable-libvidstab --enable-libvo-aa
    cenc --enable-libvo-amrwbenc --enable-libvorbis --enable-libvpx --enable-libwavp
    ack --enable-libx264 --enable-libxavs --enable-libxvid --enable-zlib
    libavutil 52. 51.100 / 52. 51.100
    libavcodec 55. 41.100 / 55. 41.100
    libavformat 55. 21.100 / 55. 21.100
    libavdevice 55. 5.100 / 55. 5.100
    libavfilter 3. 90.101 / 3. 90.101
    libswscale 2. 5.101 / 2. 5.101
    libswresample 0. 17.104 / 0. 17.104
    libpostproc 52. 3.100 / 52. 3.100
    Guessed Channel Layout for Input Stream #0.1 : stereo
    Input #0, avisynth, from 'trailer.avs':
    Duration: 00:01:26.79, start: 0.000000, bitrate: 0 kb/s
    Stream #0:0: Video: rawvideo (YUY2 / 0x32595559), yuyv422, 1920x1013, 23.98
    fps, 23.98 tbr, 23.98 tbn, 23.98 tbc
    Stream #0:1: Audio: pcm_s16le, 48000 Hz, stereo, s16, 1536 kb/s
    File 'trailer6.1920x1080p.prores422.mov' already exists. Overwrite ? [y/N] y
    Output #0, mov, to 'trailer6.1920x1080p.prores422.mov':
    Metadata:
    encoder : Lavf55.21.100
    Stream #0:0: Audio: pcm_s16le (sowt / 0x74776F73), 48000 Hz, stereo, s16, 15
    36 kb/s
    Stream #0:1: Video: prores (apcn) (apcn / 0x6E637061), yuv422p10le, 1920x101
    3, q=2-31, 2000000 kb/s, 11988 tbn, 23.98 tbc
    Stream mapping:
    Stream #0:1 (pcm_s16le) -> asetnsamples (graph 0)
    asetnsamples (graph 0) -> Stream #0:0 (pcm_s16le)
    Stream #0:0 -> #0:1 (rawvideo -> prores)
    The only way I’ve for sure been able to get the desired bitrate was to to change the profile from 2 to 3 which is Proress 422 (HQ).
    Any help would be appreciated.
    Michal Shipman
    Editor, Colorist, Director, DVD & Bluray Design
    http://www.michalshipman.com
    https://www.imdb.com/name/nm2988456/
    Reuben Martin replied 12 years, 9 months ago 2 Members · 2 Replies
  • Reuben Martin
    November 8, 2013 at 4:17 pm
    You can’t compare the bitrates of ProRes encoded by ffmpeg to the bitrates encoded by Apple software. The ffmpeg implementations are much more efficient than the apple implementation. Basically the DC transforms used by Apple suck.
    Bitrate doesn’t matter. Quality of encoding matters. FFmpeg is not going to use the full 200 MBit bandwith when the content of the video does not require that much bandwidth to encode.
    If you want to ensure the absolute highest quality, ditch the bitrate settings, and set the qscale to 1.
    -qscale:v 1
  • Reuben Martin
    November 8, 2013 at 4:21 pm
    Oh, and set the profile to 3.
