Activity Forums Compression Techniques FFMPEG MP3/WAV/PCM Gradually Increase Volume Over 5-10 Seconds
  • FFMPEG MP3/WAV/PCM Gradually Increase Volume Over 5-10 Seconds
    Posted by Jeff Bruns on July 16, 2012 at 3:43 pm
    Greetings-
    I’m using a third party utility to RTP audio files over my local network. The audio files are typically MP3/WAVE/PCM. I need to RTP one of these audio files to a multicast address but need to have the volume gradually increase over 5-10 seconds as its heard at the endpoint. Since the gradual fade-in happens dynamically depending on scenario I’m hoping to be able to use FFMPEG or another similar utility to do it on the fly and pipe the resulting audio stream into my RTP utiltiy.
    Any help with how to do this using FFMPEG or similar would be appreciate.
    Thanks.
    Jeff Bruns replied 14 years, 1 month ago 1 Member · 0 Replies
  • 0 Replies
