Activity Forums Compression Techniques ffmpeg -map audio option
  • ffmpeg -map audio option
    Posted by Kev James on April 8, 2014 at 9:26 am
    Hi, I am trying to export all audio channels from a quicktime file which has the following audio configuration:
    Track 1 – mono
    Track 2 – mono
    Track 3 – mono
    Track 4 – mono
    Track 5 – mono
    Track 6 – mono
    Track 7 – stereo
    I am using:
    ffmpeg -i Feature.mov -map 0:1 -y Left.wav -map 0:2 Right.wav -map 0:3 Center.wav -map 0:4 LFE.wav -map 0:5 Left_Surround.wav -map 0:6 Right_Surround.wav -map 0.7 L+R_Total.wav
    But this is giving me an error. So I want to output 6 mono wavs and 1 stereo wav.
    How do I do that?
    Kind regards.
    Stephen Dixon replied 12 years, 4 months ago 2 Members · 1 Reply
  • Stephen Dixon
    April 9, 2014 at 2:11 pm
    Stream numbering starts at 0. Check with ffprobe to make sure you’re using the right specifier for each stream.
    Also, post the error.
    Stephen Dixon
    Editor, Animator, Motionographer
    Museum Victoria
