Activity Forums Compression Techniques ffmpeg make install error
  • ffmpeg make install error
    Posted by Ryan Mcmurray on March 6, 2012 at 6:13 pm
    i had ffmpeg installed via macports and then i noticed i didn’t have libfaac enabled. i also was seeing issues with my encoded outputs not having the bit rates or other parameters that i had specified in my commands.
    i decided to do a more manual re-install so i went by this guide https://pitchpublish.com/?p=173 until i had this error upon finally running install:
    $ sudo make install
    INSTALL libavdevice/libavdevice.a
    LD libavutil/libavutil.51.dylib
    ld: library not found for -lXfixes
    collect2: ld returned 1 exit status
    make: *** [libavutil/libavutil.51.dylib] Error 1
    that was yesterday. today, i decided to try installing a different build of ffmpeg so i followed this guide (i’m running snow leopard on my mac) https://www.itecsoftware.com/install-ffmpeg-on-mac-snow-leopard
    now i get this error when i install:
    Undefined symbols:
    “_sem_timedwait”, referenced from:
    _audio_read_packet in libavdevice.a(jack_audio.o)
    ld: symbol(s) not found
    make: *** [ffmpeg_g] Error 1
    i have wasted a lot of time trying to get ffmpeg back and running correctly. i’ve googled everything i can think of and the answers i’m finding are too technical for me. i need clear instructions on what i might be able to do to fix this problem. i know jack and libavdevice are both in /usr/local/include but i don’t know what to do with them (if anything).
    any ffmpeg install wizards out there that might be able to lend a hand?
    thank you,
    -ryan
    Ryan Mcmurray replied 14 years, 6 months ago 2 Members · 4 Replies
  • Reuben Martin
    March 8, 2012 at 3:24 am
    The jack audio library / include files you have are probably not the correct version. I seriously doubt you need jack support on a Mac anyway. Disable jack support when setting up your configure options.
  • Ryan Mcmurray
    March 8, 2012 at 3:45 pm
    thanks reuben!
    with this in mind i rm’d the jack directory from /usr/local/include
    and i rm’d jack* from /usr/local/lib
    i rm’d the ~/ffmpeg folder and ran command:
    svn checkout svn://svn.ffmpeg.org/ffmpeg/trunk ffmpeg
    i cd to ffmpeg and run configure
    ./configure –enable-gpl –enable-version3 –enable-nonfree –enable-postproc –enable-pthreads –enable-libfaac –enable-libmp3lame –enable-libopencore-amrnb –enable-libopencore-amrwb –enable-libtheora –enable-libx264 –enable-x11grab –enable-libvpx
    then i run make and now i get a shiny new error:
    Option number is ambiguous (number-footnotes, number-sections)
    Try `texi2html –help’ for more information.
    make: *** [doc/developer.html] Error 2
    what did i do to be cast into ffmpeg install hell this time?
  • Reuben Martin
    March 8, 2012 at 5:05 pm
    run “./configure –help” to get a listing of all the options you can set. You can disable building documentation by appending “–disable-doc”. From your config that you listed, you will probably want to disable x11grab as well. That functionality is kinda pointless on a Mac.
  • Ryan Mcmurray
    March 8, 2012 at 5:11 pm
    hi all,
    i found the root cause of this error and finally got ffmpeg installed.
    here’s what i did (in more detail than most command line veterans need because that’s how i like MY instructions) in case anyone else runs into this problem:
    in Terminal, run command:
    texi2html -version
    i found i was running version 5.0 of texi2html.
    i read this post:
    https://groups.google.com/group/ffmbc-discuss/browse_thread/thread/9fdf9194a583e7aa?pli=1
    where i learned that 5.0 is an old build and that i should remove it so a later version located in /usr/bin would be used in the ffmpeg make install instead.
    so i ran command:
    ls /usr/bin/texi2html
    to make sure i had a version of texi2html in my /usr/bin
    then i ran command:
    which texi2html
    to find out the location of texi2html that my system was seeing by default.
    second to last, i got rid of the old version of texi2html by running command:
    sudo rm /opt/local/bin/texi2html
    and lastly, from the ~/ffmpeg folder i ran command:
    sudo make install
    and voila! install completed with no error.
    love the cow.
    -ryan
