Activity Forums Compression Techniques ffmpeg is not converting
  • ffmpeg is not converting
    Posted by Ola Leke on June 12, 2011 at 12:36 pm
    I have the latest version of ffmpeg in my website project. I am using asp net c# and visual web developer express 2010 for the website building.
    I don’t know what I am coding wrong if at all. otherwise it must be permission issue. and in this regard, I have tried all I can giving permission to entire project folder but still no conversion.
    This same code works fine and converts last two months where as at that time I was using windows vista. but now I upgraded to Windows 7.
    please someone, an expert, who knows about these issues should help. I am a little girl learning, doing and writing programs.
    here are my code:
    #region DoingUploadingNewVideos
    public static void DoingUploadingNewVideos(DateTime UploadedDate, TextBox BoxVideoname, Label UploadStatus, FileUpload Video, Label ImgStatus, string US, Label ExLabel)
    try
    Byte[] bytes = Video.FileBytes;
    System.IO.MemoryStream ms = new System.IO.MemoryStream(bytes);
    Guid Id = GetRegUserId(US);
    var extension = System.IO.Path.GetExtension(Video.FileName);
    if (extension.ToLower() == ".wm" || extension.ToLower() == ".wmv" || extension.ToLower() == ".asf" || extension.ToLower() == ".m2ts" || extension.ToLower() == ".m2t" || extension.ToLower() == ".mov" || extension.ToLower() == ".qt" || extension.ToLower() == ".avi" || extension.ToLower() == ".wtv" || extension.ToLower() == ".dvr-ms" || extension.ToLower() == ".mp4" || extension.ToLower() == ".m4v" || extension.ToLower() == ".mpeg" || extension.ToLower() == ".mpg" || extension.ToLower() == ".mpe" || extension.ToLower() == ".m1v" || extension.ToLower() == ".mp2" || extension.ToLower() == ".mpv2" || extension.ToLower() == ".mod" || extension.ToLower() == ".swf" || extension.ToLower() == ".flv")
    int VideoSize = Video.PostedFile.ContentLength;
    if (VideoSize < 50001000)
    #region Process
    string postedfilename, SavePath, Filenamewithpath;
    #region swf format
    postedfilename = Video.PostedFile.FileName;
    string pth = AppDomain.CurrentDomain.BaseDirectory;
    SavePath = pth + "Folders" + "\UserVideo\" + US + "\";
    DirectoryInfo di = new DirectoryInfo("" + SavePath + "");
    if (!(di.Exists))
    di.Create();
    string NewFName = postedfilename;
    NewFName = NewFName.Substring(NewFName.LastIndexOf("\") + 1, NewFName.Length - NewFName.LastIndexOf(".")) + "." + NewFName.Substring(NewFName.LastIndexOf(".") + 1);
    Filenamewithpath = SavePath + NewFName;
    //Save The file
    Video.PostedFile.SaveAs(Filenamewithpath);
    //Start Converting
    string inputfile, outputfile, filargs;
    string withoutext;
    //Get the file name without Extension
    withoutext = Path.GetFileNameWithoutExtension(Filenamewithpath);
    //Input file path of uploaded image
    inputfile = SavePath + NewFName;
    //output file format in swf
    string swfpath = SavePath + "FLV\";
    outputfile = swfpath + withoutext + ".flv";
    DirectoryInfo diswfpath = new DirectoryInfo("" + swfpath + "");
    if (!(diswfpath.Exists))
    diswfpath.Create();
    string spath;
    //file arguments for FFMPEG
    filargs = "-i" + "" + inputfile + "" + "-ar 22050" + "" + outputfile + "";
    spath = AppDomain.CurrentDomain.BaseDirectory;
    Process proc;
    proc = new Process();
    proc.StartInfo.FileName = spath + "\ffmpeg\ffmpeg.exe";
    proc.StartInfo.Arguments = filargs;
    proc.StartInfo.UseShellExecute = false;
    proc.StartInfo.CreateNoWindow = true;
    proc.StartInfo.RedirectStandardOutput = true;
    try
    proc.Start();
    catch (Exception ex)
    ExLabel.Text = ex.Message;
    proc.WaitForExit();
    proc.Close();
    #endregion
    #region thumbnails
    //Create Thumbs
    string thumbpath, thumbname;
    string thumbargs;
    thumbpath = SavePath + "Thumb\";
    DirectoryInfo dithumbpath = new DirectoryInfo("" + thumbpath + "");
    if (!(dithumbpath.Exists))
    dithumbpath.Create();
    thumbname = thumbpath + withoutext + "1" + ".flv";
    thumbargs = "-i" + inputfile + "-vframes 1 -ss 00:00:03 -s 150x150" + thumbname;
    Process thumbproc = new Process();
    thumbproc.StartInfo.FileName = spath + "\ffmpeg\ffmpeg.exe";
    thumbproc.StartInfo.Arguments = thumbargs;
    thumbproc.StartInfo.UseShellExecute = false;
    thumbproc.StartInfo.CreateNoWindow = true;
    thumbproc.StartInfo.RedirectStandardOutput = false;
    try
    thumbproc.Start();
    thumbproc.WaitForExit();
    thumbproc.Close();
    #endregion
    #region img
    //Create imgjpegs
    string imgjpegpath, imgjpegname;
    string imgjpegargs;
    string imgjpegre;
    imgjpegpath = SavePath + "Imgjpg\";
    DirectoryInfo diimgjpegpath = new DirectoryInfo("" + imgjpegpath + "");
    if (!(diimgjpegpath.Exists))
    diimgjpegpath.Create();
    imgjpegname = imgjpegpath + withoutext + "%d" + ".jpg";
    imgjpegargs = "-i" + inputfile + "-vframes 1 -ss 00:00:03 -s 150x150" + imgjpegname;
    Process imgjpegproc = new Process();
    imgjpegproc.StartInfo.FileName = spath + "\ffmpeg\ffmpeg.exe";
    imgjpegproc.StartInfo.Arguments = imgjpegargs;
    imgjpegproc.StartInfo.UseShellExecute = false;
    imgjpegproc.StartInfo.CreateNoWindow = true;
    imgjpegproc.StartInfo.RedirectStandardOutput = false;
    try
    imgjpegproc.Start();
    imgjpegproc.WaitForExit();
    imgjpegproc.Close();
    #endregion
    File.Delete(inputfile);
    #endregion
    else
    UploadStatus.Text = Resources.Lang.TooBigVideoSize;
    UploadStatus.ForeColor = Color.Red;
    else
    UploadStatus.Text = Resources.Lang.NotOurValidVideoFormat;
    #endregion
    Ola Leke replied 15 years, 2 months ago 1 Member · 0 Replies
  • 0 Replies
