Activity › Forums › Compression Techniques › ffmpeg ffv1 lossless question-
  • ffmpeg ffv1 lossless question-
    Posted by Ryan Smith on May 12, 2011 at 11:48 pm
    Hi-
    I am attempting to encode a tif sequence using ffv1 lossless compression. Upon encoding to FFV1 and decoding back to TIF, my image is not identical.
    I am able to encode fine using the following command:
    ffmpeg -f image2 -i c:/LTTemp/%03d.tif -vcodec ffv1 out2.avi
    I can then take that avi file and extract it back into a tif sequence using the following:
    ffmpeg -i out2.avi c:/LTTemp/2/image%d.tif
    I get a warning that my original tif image is PAL8 and will be converted to YUV420P which I believe to be my problem, however I am stuck on how to remedy this. My input image type is a 2D unsigned char tif written to disk using ITK. Thanks in advance-
    -Ryan
    Ryan Smith replied 15 years, 4 months ago 1 Member · 0 Replies
  • 0 Replies
