Activity › Forums › Compression Techniques › FFMPEG dropping all frames.
  • FFMPEG dropping all frames.
    Posted by Kanishk Dudeja on July 17, 2014 at 8:14 am
    I have a raw H264 video which i am trying to convert into MP4 by the command:
    ffmpeg -i ‘Camera 4(172.16.2.12_554)_1_2014_07_16_15_20_08.h264’ ‘Camera
    4(172.16.2.12_554)_1_2014_07_16_15_20_08.mp4’
    FFMPEG keeps dropping all frames. Not even 1 frame is encoded.
    Please see the output below:
    Seems stream 0 codec frame rate differs from container frame rate:
    2400000.00 (2400000/1) -> 24.00 (24/1)
    Input #0, h264, from ‘Camera 4(172.16.2.12_554)_1_2014_07_16_15_20_08.h264’:
    Duration: N/A, bitrate: N/A
    Stream #0.0: Video: h264 (Baseline), yuv420p, 1280×960 [PAR 1:1 DAR
    4:3], 24 fps, 24 tbr, 1200k tbn, 2400k tbc
    File ‘Camera 4(172.16.2.12_554)_1_2014_07_16_15_20_08.mp4’ already exists.
    Overwrite ? [y/N] y
    [buffer @ 0x820c140] w:1280 h:960 pixfmt:yuv420p
    Output #0, mp4, to ‘Camera 4(172.16.2.12_554)_1_2014_07_16_15_20_08.mp4’:
    Metadata:
    encoder : Lavf53.21.1
    Stream #0.0: Video: mpeg4, yuv420p, 1280×960 [PAR 1:1 DAR 4:3], q=2-31,
    200 kb/s, 24 tbn, 24 tbc
    Stream mapping:
    Stream #0.0 -> #0.0
    Press ctrl-c to stop encoding
    ^Zame= 2 fps= 1 q=2.0 size= 225kB time=0.08 bitrate=22147.4kbits/s
    dup=0 drop=842
    Kanishk Dudeja replied 12 years, 2 months ago 1 Member · 0 Replies
  • 0 Replies
