Activity Forums Compression Techniques ffmpeg CPU 100%
  • ffmpeg CPU 100%
    Posted by James Zeng on July 18, 2012 at 8:23 am
    Hi, FFMPEG, as some may know, uses almost 100% of the CPU. What I am wondering is that if there is a way to stop it’s resource hogging or set it at a lower priority. Maybe something to do with using a slow preset??
    Stephen Dixon replied 14 years, 1 month ago 2 Members · 1 Reply
  • Stephen Dixon
    July 18, 2012 at 12:05 pm
    you can use nice if you’re on linux/os x eg:
    nice 20 ffmpeg…
    This will give it a lower priority (the higher the number the lower priority the process is), but of course if there is nothing else using the CPU it will still take 100% of the available cpu time.
    Nice can also be used for evil of course, you can set it to 0 to take high priority, or if you have super user rights set it to -20 to be really un-nice.
    Windows users can use the start command
    start [/LOW | /NORMAL | /HIGH | /REALTIME | /ABOVENORMAL | /BELOWNORMAL] ffmpeg…
    Stephen Dixon
    Editor, Animator, Motionographer
    Museum Victoria
