Activity Forums Compression Techniques ffmpeg command creates a file too big
  • ffmpeg command creates a file too big
    Posted by Yuval Yellin on August 8, 2010 at 2:55 pm
    I run this command:
    /usr/bin/ffmpeg -i “inputfile.avi” -sameq -ss 0:0:0 -t 60 “outputfile.avi”
    And I get the correct 60 seconds video, however the file size is 300MB, while the original 20 minute long file is 170MB….
    what is wrong? how can I fix this filesize problem?
    Michael Rampe replied 16 years ago 2 Members · 1 Reply
  • Michael Rampe
    August 9, 2010 at 7:16 am
    I would like to see the full terminal output to correctly diagnose but:
    I am guessing that it is a combination of using the -sameq flag and not specifying a video codec. The full command line output will verify that.
    Instead of using “-sameq”, try using “-vcodec copy” which will not recompress the frames and should result in a more realistic file size.
    Michael
    “half-way to world domination A.K.A. the belligerent blue bike shed”
