Activity › Forums › Compression Techniques › FFMPEG and Flumotion
Posted by Klaus Bucher on September 25, 2010 at 9:37 amHi all,
is it possible to stream with ffmpeg by http to a flumotion server?
(want to stream with vp8)
Thanks for any hintsMichael Rampe replied 15 years, 11 months ago 2 Members · 4 Replies -
Klaus Bucher
October 2, 2010 at 8:55 amLooking a little deeper into flumotion, I don´t think that it is possible, cause Flumotion uses “Managers” and “Workers” for communication, and I don´t think that ffmpeg could connect to a manager and act as a “worker”, but not 100% sure.
Klaus -
Michael Rampe
October 3, 2010 at 6:47 amThere does appear to be a FFmpeg plug-in for GStreamer hosted on the GStreamer site.
QUOTE: “GStreamer FFmpeg plug-in contains one plugin with a set of elements using the FFmpeg library code. It contains most popular decoders as well as very fast colorspace conversion elements.”
https://gstreamer.freedesktop.org/modules/gst-ffmpeg.htmlFlumotion works on top of GStreamer to my understanding. Not sure if this will help in your situation but shows promise as there is some “collaboration” going on. It might be an idea to raise your issue with Flumotion and/or GStreamer…
Michael
