Activity Forums Compression Techniques ffmpeg adobe flash mp4 conversion problem
  • ffmpeg adobe flash mp4 conversion problem
    Posted by Ofer Kruzel on September 21, 2011 at 7:37 am
    I’m using ffmpeg to convert flash player created h.264 file to ffmpeg format.
    Its part of a larger functionality.
    problem
    I’m running the following command:
    ffmpeg -i ‘host.mp4’ -y -an -vcodec libx264 -b 1200k -r 25 -threads 0 -y ‘singlevideoconvert.ts’
    the original file is ~6 sec long.
    after conversion, when plating, for example with ffplay, video playback is freeze for about 6 sec, then start playing, and after another 6 sec video freezes again, but ffplay seems to keep going
    more info
    ffmpeg wrongly reports duration of 20 sec
    Mp4Box says it ~6 sec, which is correct.
    I can provide files and logs.
    help welcomed.
    Ofer
    Ofer Kruzel replied 14 years, 11 months ago 1 Member · 0 Replies
  • 0 Replies
