Activity Forums Adobe After Effects ‘Ferris Wheel’ of comps
  • ‘Ferris Wheel’ of comps
    Posted by Graeme Moodie on May 13, 2011 at 2:20 pm
    What would be the best way to create a 3d composition of 10 comps, placed in a ‘ferris wheel’-like shape, that could be rotated on its y axis, but all the comps would continue to face forward [ each facing the z axis ] and each one would continue to stay ‘upright’ [they don’t have to swing about like on a real ferris wheel!]
    Is this …. easy?
    Thanks for your help – I appreciate it!
    Kevin Camp replied 15 years, 4 months ago 4 Members · 4 Replies
  • Jeremy Allen
    May 13, 2011 at 2:37 pm
    I would think you are gonna need to use some expressions for this.
    Maybe this will serve as a good starting point, or give you some other ideas to work off of..
    https://www.motionscript.com/design-guide/auto-orient-y-only.html
    8core MacPro, 3.0 GHZ, 18GB RAM, OSX 10.5.8
    C4D 11.5
    AE CS5 (10.0.2.4)
    FCP 7.0.3
    QT 7.6.4
  • Brian Charles
    May 13, 2011 at 3:21 pm
    There are some scripts here https://aescripts.com/create3dshapes/ that automate the process.
    Create a 3D Cylinder and set the Auto Orientation property to Towards Camera. Use the Controller Null to rotate the cylinder 90 degrees in Z then animate the X Rotation. You’ll need to rotate each layer of the cylinder 90 degrees in Z independent of the Controller to re-orient them to the Comp.
  • Graeme Moodie
    May 13, 2011 at 4:30 pm
    Thanks to both of you – I will look into the link and also try out your suggestion, Brian
    Thanks – its appreciated!
  • Kevin Camp
    May 13, 2011 at 4:37 pm
    you could also use an expression for position of the ‘cars’, leaving rotation completely uneffected:
    radius = 100;
    period = .5; // number of rotations per second
    num = 6; // number of layers to rotate
    i = index;
    x = value[0];
    y = value[1] + Math.sin(2*Math.PI*(period*time+i/num)) * radius;
    z = value[2] + Math.cos(2*Math.PI*(period*time+i/num)) * radius;
    [x,y,z]
    the layer will rotate around its position, ie, if its initial position is [-540, 860, 0] it will rotate around that point. set num to the number of ‘cars’ that will rotate. the expression assumes that the the top most layers are the ‘car’ layers, change i to a unique fixed number between 1 and num, ei, if you have 5 ‘cars’ the value for i could be 1, but no other ‘car’ layer could use 1, so the next ‘car’ would be 2, the next 3 and so forth.
    Kevin Camp
    Senior Designer
    KCPQ, KMYQ & KRCW
