Activity › Forums › Apple Final Cut Pro Legacy › Feet & Frames in 16mm?
Posted by Sebastian Leda on July 8, 2005 at 4:17 pmIs there a way to display feet & frames in the timeline for a 16mm (20 frames per foot) project?
I can only get it to display 16 frames per foot.
Sebastian Leda
Editor
Digital Post ServicesSebastian Leda replied 21 years, 2 months ago 4 Members · 6 Replies -
Richard Blakeslee
July 8, 2005 at 6:31 pm16 frames a foot is for 35mm film. (24fps x 60 sec. = 1440 frames divided by 90 feet per minute = 16 frames per foot) 40 frames to the foot is 16mm. (24 fps x 60 sec. = 1440 divided by 36 feet per minute = 40 frames per foot) I don’t know what 20 frames a foot is. (Could be 16mm at 12 frames per second?)
Sebastian Leda
July 8, 2005 at 7:54 pmYou are right. There is 40 frames per foot in 16mm at 24 fps. But when I did the setup in Cinema Tools and FCP the only options I get is for 16mm 20 (i’m not sure how is this related).
But it makes sense with the keycodes, they advance one foot every 20 frames. After 0000+19 it goes to 0001+00. But the feet & frames counter in the FCP timeline goes 0000+15 and the next number is 0001+00, which is ok for 35mm but not for 16mm in relation to the keycodes.
Does this makes any sense to anyone?
Sebastian Leda
Editor
Digital Post Services -
Steven Gonzales
July 9, 2005 at 8:01 pm16MM 20 means 16mm with 20 frames between keycodes.
There are still forty frames in a foot, but there are two keycodes in a foot also.
So if you are rewinding 100 keycode numbers, then it would be 50 feet. Of course, you’re on a computer, so why am I talking about rewinds?
Sebastian Leda
July 9, 2005 at 8:34 pmOk, now that the whole 20 frames 40 frames issue is clear, can I make the FCP timeline give me 40 frames per foot display on the timeline? or 20 frames per keycode? or any kind of 16mm related reading?
I can only get it to display 16 frames per foot which is for 35mm.
Sebastian Leda
Editor
Neil Sadwelkar
July 10, 2005 at 2:19 pmOK this looks like a bug. I don’t have FCP 5 yet, but in FCP 4.5 if one put a “Timecode generator” filter on a clip and switched to 16 mm, you god 40 frames per foot and the feet+frames counter incremented to a foot after 39 frames.
I know this is not like the timeline footage display, but at least it understood 40 frames per foot. Make sense?Neil
Sebastian Leda
July 11, 2005 at 6:56 pmThanks, I didn’t know that. Now I found a workaround. I made a nested clip and applied that filter. It’s not as good as having it display in the timeline, but at least now I know the size of my reels in feet & frames!
Sebastian Leda
Editor
