Activity › Forums › Canon Cameras › Feeding the HV30 with an inverter
  • Feeding the HV30 with an inverter
    Posted by Philippe Verdoni on June 22, 2010 at 8:55 pm
    I would be gratefull if someone could share his experience using an inverter to supply 110 Volts power from a 12 Volts car cigarette lighter to the built-in HV30 battery charger
    Brian Louis replied 16 years, 3 months ago 3 Members · 6 Replies
  • Brian Louis
    June 22, 2010 at 11:02 pm
    If you are talking about using a inverter to power the Canon AC/DC adapter that plugs into the camcorder to charge the battery, I’ve done that with a HV20.
  • Philippe Verdoni
    June 23, 2010 at 7:12 am
    I also have powered my HV30 several times by the same method and the last time I have done that,it has turned out that after the camcorder had been feeded continously for 3 hours I am now experiencing misfunctionning. I believe that the camcorder software has been damaged.
  • Brian Louis
    June 25, 2010 at 11:21 am
    Hi Phillip:
    I’ve never had a problem using an inverter to power a cam through its external power supply, the external supplies are usually pretty well regualated as they have a wide ac voltage range on their input.
  • Maceo Ruiz
    June 25, 2010 at 5:28 pm
    Well, here is something to consider when using 12V inverters:
    The inverters generate noise that can cause some devices to malfunction or even be damaged. Is always good to use quality inverters. Will mention some if someone is interested on this article.
    Thanks, Maceo
    Maceo Ruiz
    Photographer
    http://www.maceoruiz.com
  • Philippe Verdoni
    June 26, 2010 at 5:52 am
    Which inverter have you used without any problem?
  • Brian Louis
    June 26, 2010 at 9:20 am
    You want to use ones that are certified for electronics use, sine wave or modified sine output
