Activity › Forums › Adobe After Effects › feedback for a beginner
  • feedback for a beginner
    Posted by N8wn8w on April 5, 2007 at 6:47 pm
    Hello,
    I am a super novice .. I just started learning after effects last week … so I know my stuff is very novice.. and I am sure I do lots of cliche things in my animation
    I would appreciate it if you could give me some constructive feedback on how I can improve my animation skills .. I am looking for feedback that will point me in the right direction
    here is my animation
    https://www.n8w.com/wp/303
    Please give me feedback … I am looking for more technical/visual feedback .. I know there isn’t a good story behind this animation ..
    example:
    music is out of sync .. see this tutorial
    the walking needs more frames at least 5 to make it look realistic
    looks novice cause the velocity is all the same .. try ease in/ease out
    etc
    any advice as far as books, tutorials, web sites, etc is greatly appreciated
    thanks
    Nate Williams
    https://www.n8w.com
    Steve Roberts replied 19 years, 6 months ago 4 Members · 6 Replies
  • Steve Roberts
    April 5, 2007 at 8:37 pm
    This is the red walking bird, yes?
    Looks fine and fun to me. It’s not realistic or polished, and shouldn’t be. It looks rough, but it’s a rough style. And that’s cool.
    What did you attempt and not achieve?
  • Kurt Murphy
    April 5, 2007 at 8:39 pm
    Nate,
    For your first AE animation I was pretty impressed… It looked good to me. I couldn’t tell if you blended layers with Transfer Modes (it didn’t look like it); but i would experiment with those a bit…
    Keep playin,’
    kurt murphy
  • Mike Procunier
    April 5, 2007 at 8:55 pm
    It looks amazing for your first animation. My first was a bunch of stupid picture-in-pictures.
  • Steve Roberts
    April 5, 2007 at 9:01 pm
    Yep, you have a lot of heart, style and energy. Can’t train that into somebody … 😉
  • N8wn8w
    April 5, 2007 at 10:24 pm
    thanks ..
    somethings I don’t like about it right now .. is the bird seems to float and is not really synced with the background … when working in ae I am still trying to figure out timing … I don’t know if this is just experience knowing how long 2 seconds is .. or if there is a tool that gives you a better idea of how animation will play at full speed (ie motion sketch) .. I have tried munipulating the curves of the time graph .. but it still seems pretty abstract to me
    the music seems a bit off as well .. I wanted something fast … no eletronic .. but metal might not work either
    the legs also seem off .. is there any type of animation rule where something needs a certain amount of frames to look real?
    thanks
  • Steve Roberts
    April 6, 2007 at 1:46 am
    You want it to look real? Why?
    The bird doesn’t have to sync with the background. Loosen up! It’s an abstract weirdy thing! Terrific!
    Okay, sure you need to be able to make things look real when you have to, but not for this one — it looks great!
    But if you want it to look convincing, there’s no rule, except maybe:
    -the feet shouldn’t slide on the ground unless you want them to, as with ice
    -the character should look as if he’s putting weight on the ground at the right time
    -make sure the viewer can tell left leg from right
    If you want to learn how to do walk cycles, as animators call them, look for Richard Williams’ book, “The Animator’s Survival Kit”. It’s not CG-based, and has nothing to do with AE, but it’s good.
    Regarding the other stuff, all CG animation tools use graphs — get used to them. They take practice. Getting the feel of timing takes practice, too. “There can be no refinement without repetition”, a wise man told me.
    No, there’s no rule. There are guidelines, but not in this case. If you want to make something that looks real, shoot someone walking with a video camera then analyze the footage, frame-by-frame.
    This is animation. If it looks right, you can tell. Use your gut and build experience. You have a good start – don’t let computers and rules and plugins kill your gut instincts.
    Go forth, screw up, and learn. Then do it again. It’s the only way to be great. 🙂
    Just my opinion …
